HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Interior
Water
1997 Jeep Cherokee water on floors
MOUNTSCAFLA
MEMBER
1997 JEEP CHEROKEE
Interior problem
1997 Jeep Cherokee 4 cyl Four Wheel Drive Automatic
The floors in the back and passengers side are always soaking wet. There are actual puddles. Have looked for holes or leaks and can find nothing.
Friday, September 3rd, 2010 AT 5:51 PM
BLUELIGHTNIN6
MECHANIC
Check drain hose from the evaporator, if clogged it will leak water into cabin of vehicle.
Friday, September 3rd, 2010 AT 6:39 PM
MOUNTSCAFLA
MEMBER
1 POST
Tried to check the drain hose from the evaporator but could not find the hose. Any tips on where to look?
Sunday, September 5th, 2010 AT 7:06 PM
BLUELIGHTNIN6
MECHANIC
It will be located on the engine side of the firewall, below where the two A/C lines go through the firewall.
Sunday, September 5th, 2010 AT 11:20 PM
Please
login
or
register
to post a reply.
Related Water Content
1997 Jeep Cherokee Water Leaking Onto Passenger...
I Have Water Leaking Onto My Passenger Floorboard After I Run The Ac For A While. * I Have Contacted A Dealership Service Department To...
Asked by
tysonhorlacher
1997
JEEP CHEROKEE
Water On The Passenger Floor
I Am Getting Water On The Front Passenger Floor And It Is Heavy Most Of The Time. What Could Be Leaking? I Can Not See Anything?
Asked by
mauicraig
1998
JEEP CHEROKEE
Jeep Leaking Water
I Have A Jeep Cherokee Laredo 1997 V8-- It Has A Problem With The Temperature Going Above 210 And Leaking Water When The Air Conditioner Is...
Asked by
jabecno
JEEP CHEROKEE
2000 Jeep Cherokee Water Inside Car
I Have Water Inside Of My Passanger Side Floor And On The Floor Of The Rear Passanger.I Was Thinking It Could Have Been Water From A Puddle...
Asked by
Pedritosmiles
1 ANSWER
2000
JEEP CHEROKEE
2003 Jeep Cherokee
Two Passenger Vents Above The Glove Box And Passenger Floor And Passenger Defrost Vents Draw In Outside Air With Single Control A.C Or Heat...
Asked by
Waternut
2003
JEEP CHEROKEE
VIEW MORE
Seat Switch Replacement
Window Switch Replacement and Test
Hood Open
