1997 Jeep Cherokee Tranny problem
144,000 MILES • 6 CYL • 4WD • AUTOMATIC
LUMBERJACK1
I have a 97 grand cherokee that has the 42re trans.
It simply stopped moving the other day after running fine before.I changed the filter and fluid and now it drives.It still don't shift quite right and when you stop in gear it whines fromthe pan(if you're moving it sounds normal).I used atf+4 fluid and have checked the level several times both cold and hot.Also today when the tranny got hot it would just die when you put it in gear.Any ideas short of having to rebuild or replace the tranny would be very helpful.Thanks
Jan 5, 2010 at 10:39 AM
  • 110,248 POSTS
It sounds like it could be rebuild time. However, it could have to do with the torque converter or front pump. With these issues, you need to have a trans tech drive it to determine where the problem is coming from.
Jan 9, 2010 at 4:03 PM
