1997 Jeep Cherokee need help with my new pice of junk
BAJAKILLER22
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 116,000 MILES
Hi my name is nick and I have a 1997 jeep cherokee 2WD this whit know is worng with it and I need your help I have poor idle in drive it idles fine in park or when you hit the gas but with the brake on it trys to stall also the heater has no austment I meen you can put it on the floor defroster vent and it is always blowing out of the defroster I think it might be a vacume leek also the speeddo dose not work and no revirse lights may be related I dont know no check engin light
Tuesday, December 11th, 2007 AT 8:53 PM
JEFFYTUNE
  • 12 POSTS
Hi Nick.
I would ask you to please re-read your question, and to please re-write it. I am having a hard time following what you are asking.
As to your Idle issue, I would start by getting a spray can of THROTTLE BODY cleaner. (Do not use carburetor cleaner).
Now with an old tooth brush and the engine of, remove the air boot off the throttle body, oak down the throttle blade(Both sides) and scrub the coke of it.
Once it is all loosed up. Start up the engine and rinse the throttle clean.
Be sure to do this outside in a well vented area.
Jeff M.
Wednesday, December 12th, 2007 AT 2:34 AM
