1997 Jeep Cherokee miss
TEDHOGAN
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 150,000 MILES
I have a dead miss on the front cylinder. Checked compression about 115 on alll except front cylinder about 50 lbs. It ran hot, maybe warped valve? The plug is firing. Any quick fix?
Thursday, March 27th, 2008 AT 8:04 AM
Do a wet test if it rises its a ring problem remains low valves-or perform a cylinder leakdown test if you have the tester-There's no easy fix for a cylinder that's leaking compression has to be torn apart.
Thursday, March 27th, 2008 AT 9:03 AM
