1996 Jeep Cherokee battery
JUNBUG3820
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 145,000 MILES
I just bought a brand new battery and if the jeep makes it to the my location when I get back in the battery is dead when I start the jeep the battery post set off a spark can it be a short or the cables on the jeep.
thank you
Friday, March 5th, 2010 AT 9:01 PM
CJ MEDEVAC
  • 11,005 POSTS
See my profile.#1 are cables POS + NEG on correct posts. OR. Battery terminals, on BATT, not reversed, or MIRROR image of OLD BATT.(WRONG BATT SET-UP, case backwards)
BATT connections good and tight?
Do all ACCs work on rig prior to starting rig?
If starter won't turn over. Lights dim out. Sparkage. Starter may be hung up in flywheel teeth. Pull starter. Re-install starter. Try again. HOPE I HELPED YOU. LET ME KNOW.
Love, Turddog
Friday, March 5th, 2010 AT 9:36 PM
