1996 Jeep Cherokee
GARY53
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 125,000 MILES
When I brake the gauges stop working
Saturday, January 19th, 2008 AT 8:44 AM
MCQUE
  • 20 POSTS
When you press the brake pedal, you must be pressing on a wire harness or causing some pressure to a wire harness somewhere under the dashboard.
Specifically you are probably loosing the ground connection for the instrument panel or the power connection. You will have to get under there and take a look see what moves when the pedal is pressed.
Sunday, January 20th, 2008 AT 4:39 PM
