1995 Jeep Cherokee rough idle
1995 JEEP CHEROKEE
18,500 MILES • 6 CYL • 4WD • AUTOMATIC
WEDIVE
When it gets above 80 degrees outside and i have been driving for about 4 hours on country roads then come into town and slow down my jeep's idle is rough and when i try to step on gas it seems like it's not getting enough. It bogs down and doesn't want to go. I put it into Neutral and rev engine and then it goes again but still idles rough and wants to die. Jeep drives fine when cold outside. Just had oxygen censor changed but that didn't help.
May 5, 2010 at 7:42 PM
  • CERTIFIED EXPERT
Hi wedive, Welcome to 2carpros and TY for the donation
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 6, 2010 at 12:24 AM
