1995 Jeep Cherokee Low reading temp gauge
1995 JEEP CHEROKEE
220,000 MILES • 6 CYL • 4WD • AUTOMATIC
95JEEP
Temp gauge never gets above 120 degree's. Installed new temp sending unit with no results. Runs O.K. and has decent cabin heat. Not sure if car is actually running cool or issue with gauge?
Dec 22, 2009 at 8:13 AM
CRZYDRVR
  • 432 POSTS
It could be the coolant temp sensor that feeds the info to the gauge that would in turn effect the reading on the dash.
Dec 22, 2009 at 11:00 PM
CHULEGAARD@HOTMAIL.COM
  • 35 POSTS
You have a bad or cold temp thermostat. Change it with the warmer temp thermostat.
If you live in a hot summer climate you may want to throw the colder thermostat in the summer months to prevent any type of overheating while idling
Dec 28, 2009 at 10:45 AM
