1995 Jeep Cherokee Idles Rough
TENNMAN1990
  • 1995 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 142,000 MILES
I just replaced my spark plugs and wires to fix a rough idle problem I was having. I replaced the plugs in the order that they were on the old cap but now the car idles harder than before. I can feel it miss a beat every few seconds or so. I checked the distributor cap and rotor. I know they need to be replaced but I dont understand how the car is running worse with new plugs. The plugs are Bosch brand and I was told equivalent to OEM. Suggestions?
Monday, April 26th, 2010 AT 9:58 PM
Could be wrong gap and type or not firmly connected at both ends might consider changing the cap and rotor
Tuesday, April 27th, 2010 AT 4:22 AM
TENNMAN1990
I put the old plugs back in to see if I could get it to go back to acting how it had been and it is still rough. At the moment the only thing "new" on it is the wires. I know the cap and rotor could cause it to run this way but shouldn't it go back to how it was acting with the old plugs in?
Tuesday, April 27th, 2010 AT 8:33 AM
TENNMAN1990
I also put the old wires back on and it is still bad. I am completely confused.
Tuesday, April 27th, 2010 AT 9:54 AM
Something don't jive here-verify the firing order
Tuesday, April 27th, 2010 AT 11:04 AM
TENNMAN1990
I had a mechanic take a listen to it and he determined it was the first cylinder. I checked the plug and sure enough I cracked it at some point. Thanks for the help!
Tuesday, April 27th, 2010 AT 4:52 PM
