Security light alarm in the dash
1993 JEEP CHEROKEE
120,000 MILES • V8 • AWD • AUTOMATIC
VIGIDEME
Dear Srs, I have two questions:
1. I've been ''on'' the Security light in the dash about one week, How can I reset the alarm. The alarm system is not the original (I think) it is VPS model XCL, and I change the back hook door, it was so oxided and I forgot change the keylock so I can't use the keylock on it. By the way I lost the key entry, I bypassed the alarm system for a while. How can I reset the Security light on the dash? it will work swhing the key at the driver door?
2. Why the gasoline pump take so long to start when I pass the ignition switch? I have to wait untill the ''Check engine'' light comes flashing and then ''on''?
Thanks Victor
Oct 4, 2008 at 2:34 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a weak fuel pump or relay.Ifit has an aftermarket alarm system, I would remove it entirely. They sometimes "fight" withe hfactory alarms and can cause problems. The drivers door should turn off your security light, if not you need to get the rear lock re-keyed
Oct 8, 2008 at 12:55 AM
VIGIDEME
Thanks , Jack, I tried to reset the alarm from driver lock key and it does not work. Can I use the right lock key in the rear door? because It does not have se same lock key.
Wher are the fuel pump and the relay? they are easy to change by myself?.
Thanks.
Oct 8, 2008 at 1:41 PM
2CARPRO JACK
  • 11,533 POSTS
Should be able to reset the factory alarm with the rear door lock. The fuel pump is in the gas tank and the relay I would need to know which Cherokee itis, thereae 7 different ones
Oct 9, 2008 at 12:29 AM
VIGIDEME
Hi, it is a Jeep Grand Cherokee 1993, 8 Cyl, 5.2 4x4 allways.
If I unplug the Jeep system alarm (in the glove panel) the car will still running?.
I deside to change the thief system alarm because I do not have the key RF control, so how can I reset the Security light alarm in the dash panel if the rear door lock key is not the same?, can I change the right door lock key for the rear door lock key?
Thanks, Victor
Oct 11, 2008 at 4:14 AM
SANDI PENTA-STASIO
I reset my security alarm by removing negative Post & waiting a few minutes. Put it back problems solved!
Dec 20, 2018 at 4:21 AM
  • 55,428 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site. :)
This guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers, Ken
Dec 20, 2018 at 7:27 AM
