1993 Jeep Cherokee engine stalls when downshifting to stop
MPYOUNG63
  • 1993 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • MANUAL
  • 141,000 MILES
When downshifting into second or first to stop the engine stalls
Saturday, September 12th, 2009 AT 11:16 AM
  • 109,740 POSTS
Has the check engine light come on? Any vacuum leaks? Have you checked for a plugged catylatic converter?
Friday, September 25th, 2009 AT 8:23 AM
CHULEGAARD
  • 35 POSTS
Crank shaft position sensor or idle position sensor
Thursday, October 22nd, 2009 AT 4:29 PM
  • 109,740 POSTS
I'm not sure I understand your question. Did you get a trouble code identifying one of the sensors mentioned?
Also, if you slip the trans into neutral, will it still die?
Thursday, October 22nd, 2009 AT 10:23 PM
CHULEGAARD
  • 35 POSTS
Curious what of anything you just mentioned jas anything to do with transmission?
Wednesday, December 9th, 2009 AT 5:30 PM
