1993 Jeep Cherokee Any suggestions will be greatly apprecia
SPAINHOUR
  • 1993 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 159,034 MILES
My car is doing 2 obvious things. At a stop light when you are stopped it will randomly rev its self and lung forward slightly. Then when you are driving it will randomly slow down (when you are pushing the gas) and the gas pedal will make a click noise and you can also feel the click under your foot. It does it randomly not just in 1 gear. Please help
Saturday, August 21st, 2010 AT 12:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Is your check engine light on, if so what are the codes? The clicking is most likely a switch/relay that is closing and opening when it should be staying closed (or open). Test the relays out. Also check for faulty vacuum hoses under hood, this could cause the reving issue.
Saturday, August 21st, 2010 AT 10:12 PM
SPAINHOUR
The check engine light hasnt came on
Sunday, August 22nd, 2010 AT 3:51 AM
