Removal & Installation
Front
See Figures 1, 2, 3, 4, 5, 6, 7 and 8
Fig. 1: Remove the wiper arms
Fig. 2: Remove the cowl panel retaining screws
Fig. 3: Remove the cowl panel
Fig. 4: Disengage the wiper motor electrical connectionFig. 5: Unfasten the wiper motor retainers
Fig. 6: Remove the wiper motor and linkage
Fig. 7: Unfasten the wiper motor-to-linkage retaining fasteners
Fig. 8: Separate the motor from the wiper arm
Remove the wiper arm and blade assemblies.
Remove the cowl trim panel.
Disconnect the washer hose.
Remove the cowl mounting bracket attaching nuts and pivot pin attaching screws.
Disconnect the wiring harness and unfasten the wiper motor retainers.
Remove the wiper motor and the plastic motor cover, if equipped.
Remove the retainers holding the motor to the linkage assembly and bracket.
To install:
Install the retainers holding the motor to the linkage assembly and bracket.
Install the wiper motor and the plastic motor cover if equipped.
Engage the wiring harness and fasten the wiper motor retainers. Tighten the mounting nuts to 35 inch lbs. (4 Nm).
Install the cowl mounting bracket attaching nuts and pivot pin attaching screws.
Engage the washer hose, install the cowl trim panel and the wiper arm and blade assemblies
SPONSORED LINKS
Thursday, October 16th, 2008 AT 10:36 AM
