See My Profile, Imma CJ kinda Guy.
Before you answer back, Recheck your fluid and look at the insides of your tires (ALL!) Look for BRAKE FLUID Centrifically thrown down the sides, also look for fluid anywhere on the ground!
Thats just a precaution!
I do not know your rig much at all, I do know the MECHANICALS of BRAKES.....not much about the ABS systems....But I do know the End Results of what actually stops you!
Some of these newer rigs have 1) DISC BRAKES on all wheels, 2) some are disc at the front and drum on the rear. 3) Really older stuff is DRUMS on every wheel.
I suspect you are 1) or 2)
I SUSPECT you either have 3 possibilities to what your symptoms are:
1) Bad Master Cylinder (last thing to check/ replace, of these 3)
2) Brake Shoes out of adjustment or self adjusters not working (Drum Brakes)
3) Air in the lines-----Could be anywhere, in the master cylinder, in the lines, or in the Calipers or wheel cylinders.
Do you/ can you/ are you capable of these repairs or adjustments? Tools? Assistance on your end?
I MAY BE ABLE TO HELP, if you are sorta AUTO Mechanical......But if you are unsure, I will not chance your life, with Misunderstanding of a CRITICAL REPAIR that can be avoided.
I am not a paid mechanic, nor paid here, I do MY, MY FAMILY'S and FRIEND'S auto work'
I am a Whiz with CJ 5s, CJ 7s, and Scramblers
You Turn
The Medic
Oct 22, 2010 at 5:18 PM
