1992 Jeep Cherokee
ABLUE1982
  • 1992 JEEP CHEROKEE
1992 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
After driving more than a couple of miles my jeep sputters and stalls. We have replaced the o2 sensor (The code that the check engine light gave) and battery cables. What might the problem be?
Monday, December 15th, 2008 AT 3:16 PM
TGFISHEL
  • 52 POSTS
Have you done a tune up on your jeep if not try that.
Tuesday, December 16th, 2008 AT 6:34 PM
ABLUE1982
It has had a tune up and oil change. Could it possible be the crank sensor? What type of affect can that have on the performance?
Wednesday, December 17th, 2008 AT 4:04 PM
TGFISHEL
  • 52 POSTS
My jeep did the same thing was told it was fuel pump but changed out cranksensor and all is fine now.
Wednesday, December 17th, 2008 AT 4:30 PM
ANIMALFARM
  • 58 POSTS
Check out my post a couple of lines below this one in the 1997 Jeep "is it the Crank Sensor?" For a little detail regarding the symptoms of Crank Posit Sensor Failure.
After it dies, how long before you can re-start it? Hard to Start, or does it just turn over with no problem? My thinking is leaning torward "heat-related", the engine heat causing a compnent failure.
Wednesday, December 17th, 2008 AT 4:38 PM
