Hi, Are you carbed or fuel injected? The reason I ask, if your fuel injected, according to my info, makes it harder to check for mil trouble codes.
Do you have a digital multimeter, most will give inductive reading, by touching the plug wire. You don't unplug anything, you don't penetrate the insulation. You just touch the meter lead to plug wire. Say, if 4 four of the plug wires read.5 volts or close to the same, and 2 are reading zero, you found the place to start. Not conclusive test, but, a place to start.
SPONSORED LINKS
Monday, February 8th, 2010 AT 3:50 PM
