I have a 1987 Jeep Cherokee chief with the 4.0L. When i first got the jeep i noticed that if i left the Headlights on and shut the car off with my key the motor stayed running. but if i turned the headlights off then shut the car off with the key it shut off just fine. the other thing i noticed is if i left the key out of the ignition and turned the headlights on it somehow turned both the headlights on and ENGAGED THE FUEL PUMP and inside dashlights as if i had turned the key into the on position. NOW!!! the car refuses to shut off regardless if the headlights are off or on. i replaced the Ignition switch on the column,i replaced the starter Relay but still had no luck the only other thing i was told that would possibly be causing the problem is the ICM??? someone please tell me what im dealing with here?? i dont wanna pay 116bucks for a new one if i dont need too!!!!
Jun 5, 2010 at 8:55 PM
