2000 Jaguar S Type 4 runs rough at low RPM when hot
2000 JAGUAR XJS
MALBERT
I have a 2000 Jaguar S Type 4 with 160,000 miles. The engines runs fine when it is cold. After the engines has warmed up, it misses and run rough at lower RPM. If I increase the RPM either by down shifting the transmission or by accellerating, the problems goes away. When I return to cruising RPM, the problem returns. The yellow engine light is on. If I floor the gas pedal and bring up the speed to 75-80 MPH, the light will either blink for a while or go off entirely. When I resume normal speed and RPM, the light comes on again, as does the problem. Any suggestions?
Mar 1, 2007 at 4:47 AM
