1989 Jaguar XJS False high heat reading
1989 JAGUAR XJS
145,000 MILES • V12 • 2WD • AUTOMATIC
DHAYNES@PELICANSVCS.COM
The dash heat gage quickly goes to a high heat reading. If I open the hood - the engine does not seem overly hot. The electric cooling fan does not engage - so either the fan is not working, or it does not sense it is hot enough to kick in. Could this be a relay or temp sending unit, or?
Apr 19, 2009 at 12:25 PM
JAMES W.
  • CERTIFIED EXPERT
  • 2,394 POSTS
Do you have a digital or analog dash? Also, does the the temp indicator jump imediately or gradually? Please advise.
Apr 19, 2009 at 1:43 PM
It is analog. The gage goes up fairly slowly - then very fast and sometimes rather jumpy.
Apr 19, 2009 at 1:58 PM
JAMES W.
  • CERTIFIED EXPERT
  • 2,394 POSTS
I have to believe it's a problem with the temp sending unit. If you unplug the single wire connector to the sender, the gauge should go to "0". If yes, change the unit.
https://www.2carpros.com/forum/automotive_pictures/248092_89_XJS_temp_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248092_89_XJS_temp_1_1.jpg
Apr 19, 2009 at 4:58 PM
