1989 Jaguar XJS car will not start
1989 JAGUAR XJS
86,570 MILES • V12 • 2WD • AUTOMATIC
DANELETTIERO
car was running good but was showing a low charge rate I installed a new battery and it still showed a low charge on gauge parked car and tried to start three days later and it would not start charged battery and it would not even turn over it I tried other electrical items and they all worked could it be the starter relay
Jun 17, 2010 at 10:54 AM
2 LINSEY
  • CERTIFIED EXPERT
  • 287 POSTS
Hi and thank you for using 2carpros.com. I would start by checking the voltage of your battery with a volt meter. It should read between 12.3 and 12.7 That is what it will take to turn the starter on your vehicle. As for the starter relay being bad, I would think not likely if the car was starting and running before you changed the batt and after u changed the batt. please get back to me with your results and we can go to the next step in figuring out what is going on.
Jun 21, 2010 at 7:01 PM
DANELETTIERO
THE BATTERY IS BRAND NEW AND IT HAD A FULL CHARGE COULD IT BE THE SWITCH ON THE SHIFT LEVER?
Jun 21, 2010 at 10:15 PM
2 LINSEY
  • CERTIFIED EXPERT
  • 287 POSTS
what is the current battery voltage? the switch on the shift lever is a possibility but we can not determine that untill we know a few other things first
Jun 22, 2010 at 11:27 AM
DANELETTIERO
I do not have a voltmeter but it is a new battery and I put it on a battery charger and gave it a slow charge and it was fully charged when it would not turn over I switched batterys from my 1985 coupe and car would not turn over both batterys start the 85 xjs I also tried battery from my explorer I do not think the battery is the problem is there a fuse for starter
Jun 22, 2010 at 8:34 PM
2 LINSEY
  • CERTIFIED EXPERT
  • 287 POSTS
with a test light, check to see if you are getting power to the starter and the relay.
Jun 24, 2010 at 11:51 AM
LEMONLOVER
Hi, I own what must be the all time lemon of the 1989 Jaguar XJS'. Your going to love this... I had intermittent & pretty much unexplainable probs with the battery/alt/starter circuit for years. Had me pulling my hair out.I mean really relays, diodes, more relays...on & on. SO THIS IS THE SCOOP - if the battery, alternator & starter are fine go to the starter relay, its silver, rectangular with 2 wing attachment for screws on the passenger side of the engine compartment toward the firewall. OK now, there are like 6 prongs or more, pull off the black wire with a green stripe and attach a spare wire to that prong/blade and then ground that wire to something metal. Try to start the car. Did it work? If it did, its the feed back relay (black square with an internal diode just to the right of the starter relay)Ok, now here;s the fix, keep the ground wire that you supplemented and replace the errant relay at your leisure. As long as its ground your cool. Do you believe they charge so much for something so simple? egad, I hate most mechanics
Aug 19, 2012 at 12:20 AM
