1983 Jaguar XJS Involuntary starting and stopping of aircon
NANKOOR
  • 1983 JAGUAR XJS
  • V12
  • 90,000 MILES
Hi - my aircon decides when it starts and stops - the switch needs to be on for this to happen but then there is no guaging when the system will start working and when it decides to stop. When it is working - it is fine - the only question is why does it have a mind of its own?
I suspect that the probelm may lie in the swtich - but then that is only a guess - the switch must be working otherwise it wouldn't come on when it does.
Any help will be appreciated.
Tuesday, April 13th, 2010 AT 7:10 PM
DAVE H
  • 13,384 POSTS
A/C COMPRESSOR INOPERATIVE
Defective compressor clutch. Defective super heat switch/thermal fuse. Defective heater coolant thermostat. Defective ranco thermostat. Blown ranco thermostat in-line 10A fuse (in wiring next to ranco thermostat in BRN/YEL or PNK wire). Defective main relay or no electrical power to main relay.
Thursday, April 15th, 2010 AT 3:36 AM
Related General Content
