1998 Jaguar XJ8 P1722 Gear 2 incorrect Ratio
BOSSEJAGUAR
  • 1998 JAGUAR XJ8
  • V8
  • 130,000 MILES
My question is
What do the code tell me
Is the sensor broke or the box
I can drive but I will not do so till I get an answer.
My hope is new oil and filter will fix it.
Wednesday, July 14th, 2010 AT 2:06 PM
JAGTECH360
  • 74 POSTS
Unfortunately, new oil and filter will most likely not cure your problems. Possible cause could be the J-gate module. It supplies the transmission control module with info on what position the gear selector is in.
Before that, check the mounting bracket where the shift cable attaches to the side of the transmission. These have a tendency of the bolts working loose causing the cable to move around which in turn does not select the correct gear in correlation to what the J-gate is indicating.
Tuesday, November 2nd, 2010 AT 7:15 PM
