1997 Jaguar XJ6 Sunroof
1997 JAGUAR XJ6
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIMUR78
I have a 97 Jaguar XJ6. The moonroof is not opening. I hear the motor working but it doesnt open. I am assuming something is dislocated. Do you think it is something major? what would you suggest?
thank you.
Sep 13, 2008 at 11:23 AM
JAMES W.
  • 2,394 POSTS
The drive motor is located above the overhead console above the rearview mirror. Lower the console without disconnecting the lead to the roof switch. Once you can see the drive unit, activate the switch. you should be able to see the drive turn. If it does, the drive unit is held in by 2 or 3 screws, pull it out and inspect the drive sprocket and the cables it runs. I the motor runs but sprocket doesn't turn or is chewed up, replace the unit. "IF" the cables are chewed up or worn out. It's a new ball game. You have to pull doun the entire headliner and replace the track unit itself. Good luck, jimbo
Oct 2, 2008 at 9:44 PM
