1994 Jaguar XJ6 blowing air but no heat
LGLEWIS1971
  • 1994 JAGUAR XJ6
Heater problem
1994 Jaguar XJ6 6 cyl Front Wheel Drive Automatic unknow miles
the blower motor seems to be coming on you can hear it and feel the cold air blowing in the winter( air conditioner does not work) but there is no heat coming out of the vents.
Friday, January 9th, 2009 AT 10:29 PM
JAMES W.
  • 2,394 POSTS
Are the hoses in/out for the heater core hot? If not, check the water flow valve for heater core to see if it's opening. If the hoses are hot, check the servo motors on the passenger side of the heater box under the dash to see if the air damper is switching from a/c to heat position.
Friday, January 9th, 2009 AT 10:51 PM
