1989 Jaguar XJ6 engine start up
1989 JAGUAR XJ6
87,780 MILES • 6 CYL • 2WD • AUTOMATIC
BOBBYSANTI
Engine will only start with starting fluid. Has fire to plugs and fuel to fuel rail and out of fuel regulator with pressure. New coil, crank relay, plugs, ignition amp. Cleaned MAF. After starting with starting fluid engine runs perfect, on hwy hits 120 in seconds and is smooth as silk at idle, but after turning off, will not start back up without starting fluid. Can not afford to take car to Jag shop at 70.00 hr. but would pay for the correct answer before I pull my hair out! bobbysanti@bellsouth.net or 615-870-3073
Feb 24, 2010 at 8:52 AM
DAVE H
  • 13,384 POSTS
replace the fuel pump .. it sounds like it is not supplying correct pressure for start up !!
Feb 24, 2010 at 11:55 AM
BOBBYSANTI
Dave, you might be right. Thinking back the pump gives a short burst of fuel and stops. I don't have a gauge. Auto zone has'em for 89.00. I'll replace today and if thats it I'll get back to you tonight. Is 30.00 ok for you if thats the answer? Bobby
Feb 25, 2010 at 3:34 AM
