2005 Jaguar X-Type keyless entry
55,000 MILES • 6 CYL • AWD • AUTOMATIC
RONJMCMILLAN
i changed the battery in the keyless entry fob and i can not unlock the car remotely.
it was working fine, i put the car through a car wash and it locked the car one time and then i was not able to unlock it again. i would appreciate your help.
Thanks,
ron
Jan 3, 2009 at 11:20 AM
DAVE H
  • 13,383 POSTS
Remote Transmitter Programming
NOTE:All remote transmitters are programmable and must be programmed at the same time.
NOTE:If an attempt is made to program a fifth remote transmitter after four remote transmitters have already been programmed, the generic electronic module (GEM) will exit the remote transmitter learn mode. If the remote transmitter learn mode is entered again, the attempt shall erase all remote entry device associations and start a new set of four remote entry device associations with this fifth remote transmitter programming attempt.
The complexity of the electronics involved with the remote keyless entry, of which the GEM is a part, and the multiplexed communication network which are connected to it, exclude the use of workshop general electrical test equipment. Therefore, reference should be made to the Jaguar Approved Diagnostic System for programming the remote transmitters.
Description and Operation
Oct 31, 2009 at 1:58 PM
