2004 Jaguar Vanden Plas check engine light
61,000 MILES • V8 • 2WD • AUTOMATIC
JIMMITO
multiple miss fire codes.
Runs a bit slugish idles a bit rough after warmed up. Wants to kill when backing up or moving forward slow.
had 2 different answers.
1. flush the fuel injectors ($400) Or try sea foam. (Tried sea foam)
2. Spark plugs ($350) Are those magic plugs?
Would like to fix the right thing on the first try without having to fix 5 items to figure out which one is the real problem. (They do this to me every time I go in)
May 6, 2009 at 11:27 PM
DAVE H
  • 13,383 POSTS
the injectors have a specilaised cleaning procedure .. hence the cost .. the spark plugs have individual coils fitted to each plug .. I would replace the plugs/coils first !
Nov 26, 2009 at 10:55 PM
