2000 Jaguar Vanden Plas how do i set the timing
KPADEH G. BAYSAH
Engine Mechanical problem
2000 Jaguar Vanden Plas V8 Two Wheel Drive Automatic
i neen to know how do i make the timing right
May 4, 2009 at 4:11 AM
DAVE H
  • 13,383 POSTS
Ignition timing and spark distribution are controlled by ECM or PCM according to sensor inputs. Ignition timing is controlled primarily as a function of engine load and speed. Engine load is sensed by Mass Airflow (MAF) sensor. Engine speed is sensed by a Crankshaft Position (CKP) sensor. The ECM or PCM processes inputs from the sensors and accesses ignition timing from the ignition timing strategy. Individual ignition coils are located above each spark plug. ECM or PCM incorporates the primary circuit for each coil and provides switching for each primary circuit. The correct firing sequence and timing of the ignition coils is determined by ECM or PCM from cylinder synchronization input provided by the Camshaft Position (CMP) sensor
Nov 26, 2009 at 10:30 PM
