1994 Jaguar Vanden Plas Blower wiring problem
1994 JAGUAR VANDEN PLAS
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAGMAN94
Taken blower out, bench test working fine, all fuses good, possible problem brn/blu 12 volt wiring supply NOT HOT AT ALL TIMES as manual says it should be. What else can I check being that this wire runs directly from blower to fuse box no other breaks & what problems would I encounter if I ran another 12 volt supply?
Jun 10, 2010 at 4:50 AM
DOCFIXIT
  • 18,828 POSTS
Is there power to fuse ? is yes pull fuse use ohm meter to check contiuity on wire. Problem on left or right blower?
Jun 10, 2010 at 6:00 AM
JAGMAN94
Yes there is power @ fuse, but there is no power @ wire connection 2 blower. I also have another 94 Jag xj6 where blowers work fine & when I tested it, there was power @ fuse & connection & once I pulled fuse there was still power @ connection 2 blower just @ lower voltage. Does this indicate I may have a bad fuse box in 94 Jag VDP? The blower is on the left(driver-side)
Jun 10, 2010 at 6:47 AM
DOCFIXIT
  • 18,828 POSTS
If it does not ohm out then yes mosts likely then connection at back of box
Jun 10, 2010 at 7:16 AM
JAGMAN94
Ok, I pulled the left side fuse box out of 94 Jag VDP & left battery connection connected 2 fuse box & tested each prong. I found 1 weak prong on left side of fuse box(faced down) & 4 prongs that did not light at all on right side of fuse box(face down). I then did the same to other Jag xj6 just for reference & found all lit up on left side of fuse box & the same 4 that did not light on right side of Jag VDP, did not light on other Jag xj6, but everything on Jag xj6 works fine. I understand that, that weak prong in fuse box could be my problem 2 blower, but what does the four prong not lighting at all on either car mean, being 1 car system works fine?
Jun 10, 2010 at 8:51 AM
DOCFIXIT
  • 18,828 POSTS
Those terminals will only get hot when whatever they power is turned on and complete circuit. Did you OHM check wire from fuse to motor?
Jun 11, 2010 at 1:42 AM
