1993 Jaguar Vanden Plas Ck Engine Fault Code Fuel Fail 39
JAMESAFFA
  • 1993 JAGUAR VANDEN PLAS
  • 6 CYL
  • 163,660 MILES
What does this mean? How best to repair. Engine seems to function just fine
Thursday, August 20th, 2009 AT 6:14 PM
DAVE H
  • 13,383 POSTS
DTC 39: EGR Function
With engine at normal operating temperature and transmission in Neutral, lift EGR valve diaphragm. Engine should run rough and RPM should decrease. If engine does not run rough, check EGR transfer pipe, intake manifold, and EGR valve for blockage.
If engine runs rough, apply parking brake and service brakes. With engine hot, ensure vacuum signal to EGR valve is present at 1200 RPM. If vacuum signal is not present, ensure ECM is grounding EGR control solenoid Green/Red wire or check vacuum hose routing.
If vacuum signal is present, ensure EGR valve functions properly when vacuum is applied. Replace EGR valve if necessary. Ensure ECM is receiving EGR temperature sensor signal. See the appropriate SENSOR RANGE CHARTS article in this section. Check continuity of wiring harness between ECM and EGR temperature sensor. Repair or replace as necessary.
Friday, November 27th, 2009 AT 7:52 AM
