1999 Other Jaguar Models chain slap
1999 JAGUAR
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOKI1200
  • 11 POSTS
I have been offered a 3.0 V6 S-Type Jaguar. It is a 1999-2000 and the price is £600 (my uncle is offering it to me at a family pice) The car has covered 137,000 miles and at the startup there is a slapping noise coming from the timing chain cover of the left bank (usually only for a few seconds, somtimes up to a minute). Many Jaguar forums talki of an uprated cam-chain tensioner, as the seals fail and cause a loose cam chain, my biggest fear is that it may be the big end shells causing a loss of pressure to the top end, or even the oil pump itself. Can you tell me if the cam-chain tensioners are a common fault on the 3.0 V6 and if not, what usually is. Thank you for your time. Paul
Aug 16, 2008 at 8:55 PM
2CARPRO JACK
  • 11,533 POSTS
Done them on the V-8's not too sure of the V-6's though. Usually when they come out with an updated part like that, they are kind of admitting it is a problem. If you only hear noise from one side I wouldnt worry too much about the oiling being the problem.Definitly sounds like a tensioner that is bleeding down and or slow to pump back up
Aug 17, 2008 at 2:11 AM
