Jaguar codes P1316, P0353, P0354, P0355, P0356, P0358
BLACKHONOR9
  • 2000 JAGUAR VANDEN PLAS
  • 4.0L
  • V8
  • RWD
  • 94,300 MILES
I'm getting these codes on my 2000 Jaguar Vanden Plas. I know that code 0353, 0354, 0355, 0356 are coil codes. So I moved coil 3 to 1 and 4 to 2 and coil 5 to 7 and 6 to 8. Still getting same codes with an additional P0358. I hoped the misfires would move but didn't. What should be the next step I take?
Tuesday, December 9th, 2014 AT 6:34 AM
WRENCHTECH
  • 20,761 POSTS
Those are coil CIRCUIT codes not coil codes. That means it could be anything in the circuit to include wiring, power supplies and the computer. The wiring would be your most likely suspect. I'd specifically look at connectors for that harness.
Tuesday, December 9th, 2014 AT 7:25 AM
BLACKHONOR9
  • 14 POSTS
I forgot to mention that I am receiving Coe P0305, P0304. How can I check the wiring or connectors?
Tuesday, December 9th, 2014 AT 10:56 AM
WRENCHTECH
  • 20,761 POSTS
If you don't have electrical training and knowledge and it appears you don't, then this is likely going to be a job for an electrical shop.
Tuesday, December 9th, 2014 AT 3:16 PM
