It sounds like the engine might have overheated. The smoke could be from coolant.
Did the temperature gauge go too high while this was happening?
Is there any fluid leaking under the vehicle?
Here is a helpful guide:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
A good first step would be to check the components under the hood.
Check the coolant level as well as the oil.
If there is a leak, it is a good chance there will be signs of it.
https://www.2carpros.com/articles/coolant-leak-symptoms
Until you figure out what might be the issue, it is a good idea not to start it as if it is out of coolant or oil. Starting will damage the engine.
Let me know what you find.
SPONSORED LINKS
Tuesday, December 21st, 2021 AT 7:01 AM
