Shuts off while driving after replacing the battery and alternator
89,544 MILES • 3.8L • V6 • 2WD • AUTOMATIC
KALE LAWRENCE
  • 5 POSTS
I put in a new battery and new alternator but when I start the car it drives for 10 minutes and then it shuts off. then if I jump the battery, it goes down the block and shuts off again. Sometimes it will just work the right way but if I let set for an hour it starts that again. It would go from 14 v and goes all the way down to the red. Please help
Feb 17, 2022 at 2:37 AM
  • 110,244 POSTS
When you say it goes from 14v into the red, is that with the engine running? After 10 minutes, is the battery dead?
Do me a favor. I need you to check something. It sounds like the alternator isn't working properly. I need you to check power at the battery with it running to determine if the alternator is the issue or if there is a short.
Here is a link that shows how it's done:
Do this and let me know the results. Also, when you start it and it stalls, feel the battery cables to see if they are hot.
Feb 17, 2022 at 8:43 AM
KALE LAWRENCE
  • 5 POSTS
it was the alternator it was bad and i got my money back. thank you everyone.
Feb 18, 2022 at 1:12 AM
  • 110,244 POSTS
Thanks for the update. I'm glad to hear you got it fixed. Based on your description, it sounded like the alternator was the issue.
Regardless, please feel free to come back anytime in the future if you have questions. You are always welcome.
Feb 18, 2022 at 7:20 AM
KALE LAWRENCE
  • 5 POSTS
Feb 21, 2022 at 11:01 PM
