Engine shuts off when transmission is shifted into gear
20,006 MILES • 3.0L • 6 CYL
LETHA JENNIFER CLAXTON
It ran out of gas put gas in it and now it's like it's only hitting on 2 or 3 cylinders. I've changed two of the coils so it acts a little better, but it will not move. When shifting the transmission into drive it stalls out and shuts off. It sounds like it's not getting enough gas or something to do with the computer stuff. I don't know but I need it fixed only transportation I have.
Apr 10, 2022 at 9:42 PM
  • 110,251 POSTS
Chances are when you ran out of fuel, either the pump was damaged, or it picked up dirt from the bottom of the tank and the filter is partially plugged.
What I need you to do is check the fuel pressure. You will need a gauge, but most parts stores will lend one to you.
Here is a link that explains how it is done. Take a look through it and let me know if you are comfortable performing it.
Do this first and let me know the results.
Apr 11, 2022 at 1:41 PM
