Engine Mechanical problem
1993 Isuzu Truck 4 cyl Two Wheel Drive Manual 240 K miles
I do not drive this vehicle but start it a few times a month, recently it did not want to start so I made sure the gas and oil levels were good, charged the battery and still no ignition. I primed the carb with gas and it started for a few seconds but shut off, I disconnected the fuel line to the carb and turned the key and pressed the gas pedal and saw gas coming out, reconnected the fuel line and turned the key and pumped on the gas pedal but did not smell or see any gas in the carb. Is there something between the gas inlet to the carb and the actual carb barrell that may be plugged or am I looking in the wrong area?? Thanks
Jan 7, 2009 at 6:35 PM
