1986 Isuzu Truck valve adjustment
SPAIR TIRE
  • 1986 ISUZU TRUCK
  • 4 CYL
  • MANUAL
  • 110,085 MILES
I need a diagram, and instructions on adjusting the valves on a 2.3L Isuzu moter
Monday, March 16th, 2009 AT 1:33 PM
DAVE H
  • 13,384 POSTS
VALVE CLEARANCE ADJUSTMENT
Ensure that rocker arm shaft brackets are tightened to specifications. Set No. 1 piston at TDC of compression stroke. Adjust clearance of No. 1 and No. 2 intake, and No. 1 and No. 3 exhaust valves. Turn crankshaft 360 degrees to place No. 4 piston on TDC of compression stroke. Adjust remaining valves.
VALVE CLEARANCE ADJUSTMENTS
Application. In. (Mm)
Cold
Intake .006 (.15)
Exhaust .010 (.25)
Hot
Intake .008 (.20)
Exhaust .012 (.30)
Tuesday, April 21st, 2009 AT 5:19 AM
