1996 Isuzu Trooper Cooling Problem
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
EAMEADS
My 1996 Isuzu Trooper has been overheating and the leak was coming from somewhere I couldn't distinguish. I took it to my mechanic and he said that the leak was coming from behind the intake and that they would have to remove the intake to tell what needs to be replaced. What are the chances that the replacements will be something simple like a hose, as opposed to something complicated/expensive? Thanks!
Jun 25, 2008 at 5:41 AM
KHLOW2008
  • 41,812 POSTS
Hi eameads,
The chances of hoses or it connection are higher than any other thinigs but we cannot rule out corrosion to tubes and fittings.
Not likely to be anything complicated and expensive.
Jun 29, 2008 at 12:02 AM
