The brake pedal pretty much hits the floor the first time you step on it and yields only moderate stopping power. 1 or 2 pumps later it seems to build up pressure and you get a firm pedal. Let it sit and the pedal gets soft again.
There are no fluid leaks. I've bled the snot out of the brakes and as far as I can tell there is no air in the system.
The pedal is hard and does not drop, when the car is off and also after it's pumped up.
What's going on?
What's going on?
Jul 3, 2008 at 6:36 PM
