1995 Isuzu Rodeo Question Rusted Frame
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
CRYSTAL07FRANKIE
Hi, I have a 1995 Isuzu Rodeo that has four rust spots in the frame. One is at the lower control arm, and two arms that are mounted to the frame in the middle of the vehicle and support my shocks and springs at the front. Can this be fixed? If so is it worth fixing? Thank you
Dec 14, 2009 at 12:43 PM
  • 31,937 POSTS
Hi there, if this is just surface rust it should not be a problem, best you get a panel shop to check it out and advise you if it is to deep seated for remedial action.
mark (mhpautos)
Dec 14, 2009 at 4:37 PM
