HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Isuzu
Rodeo
Engine
Symptoms
Idle High
1995 Isuzu Rodeo Question HIGH IDLE SPEED
CZRIDERJOE
MEMBER
1995 ISUZU RODEO
6 CYL
4WD
MANUAL
100,000 MILES
HOW TO ADJUST HIGH IDLE ON MY RODEO 95
Tuesday, February 2nd, 2010 AT 7:43 PM
OBXAUTOMEDIC
MECHANIC
Since it is fuel injected the Idle is Computer Controlled so there is no adjusting. You most likely have a Vacuum Leak and/or a Problem with the IAC (Idle Air Control) Motor.
Tuesday, February 2nd, 2010 AT 7:50 PM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
Idles To Fast
I Have A 1995 Isuzu Rodeo 3.2l V6. When It Cool Outside It Idles Above 3000 Rpms At A Stop. When You Drive It Down The Road Then Push In The...
Asked by
v-star07
1995
ISUZU RODEO
1992 Isuzu Rodeo Question High Idle
Okay, So I Have A 1992 Isuzu Rodeo V-6 4wd With Around 144,000 Miles On It. When I First Crank My Car In The Morning Its Goes Up To Around...
Asked by
swtpea76
1992
ISUZU RODEO
Idle High
My Question Is I Have A 1996 Isuzu Rodeo And When I Start The Truck The Idle Is High And Then I Turn It Off And Then Start It Again And Its...
Asked by
Texasgirl
1996
ISUZU RODEO
High Idle
I Just Replaced The Iac Motor And Drove It For About 1 Hour And Then 3 Hours Later Drove It For 2 Minutes Down The Road And Turned It Off To...
Asked by
babcakes2002
1996
ISUZU RODEO
1999 Isuzu Rodeo Question Engine Idles High And Stalls
Hey 2 Car Pros- This Problem Has Been Gradual. For A Long Time, My Car Would Idle High. It Would Stall After Long Trips Of 100+ Miles....
Asked by
ChrisBrecht
1999
ISUZU RODEO
VIEW MORE
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Vacuum Leak
