1992 Isuzu Rodeo Question
CASEYPRAY
  • 1992 ISUZU RODEO
Engine Performance problem
1992 Isuzu Rodeo Question 6 cyl Two Wheel Drive Manual
my isuzu was having trouble starting up and now it wont start at all I tried jump starting it, putting more gas in it I also tried starting it up and pumping the gas the battery and starter are fine it just will not turn over
Thursday, April 29th, 2010 AT 10:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If engine is cranking but not starting then need to test fuel pressure to ensure its getting fuel. If it is getting fuel then test spark at plugs.
Thursday, April 29th, 2010 AT 11:00 PM
CASEYPRAY
If it is not getting fuel is that the fuel pump?
Thursday, April 29th, 2010 AT 11:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If it's not getting fuel then the fuel pump circuit is what needs tested, yes. Start with the fuse to the fuel pump, then the fuel pump relay and lastly the wiring to the pump. If all is good here then fuel pump is shot.
Thursday, April 29th, 2010 AT 11:49 PM
