timing belt issues
ISUZU
GR8WMN
I have an 86 trooper and my timing belt broke, bent all my valves, etc. I had the cylinder head rebuilt, all new belts put on, new gaskets, etc. Less than 100 miles later my timing belt broke again. I had them check to see if a pulley was bent or something and all checked out ok. Other than a bad job by the mechanic, or a bad belt, is there maybe another thing to check which may have caused it to break again so soon? thanks
Mar 30, 2006 at 9:19 PM
KENB79764
  • CERTIFIED EXPERT
  • 52 POSTS
i believ there may have been a batch of bad isuzu timing belts manufactured, i have seen several of these. just make sure thepulleys are also spinning freely and the bolts torqued properly, not just tightened.
Apr 5, 2006 at 8:35 AM
