1993 Isuzu Rodeo Rear Rotor Stuck
ISUZU
AKSILVERWOLF
I was in the middle of replacing my rear brake pads on my 93 isuzu rodeo LS 3.2L when I found that my right rear rotor had chunks out of it caused by the inside pad slipping out of place and allowing the piston to get chewed up hitting the rotor.
Now my problem.The rotor will not come off.I found a question that said "remove the axle nut" to get the rotor off.
Where is this thing.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 10, 2007 at 4:01 PM
2CARPRO JACK
  • 11,533 POSTS
Rear disc brakes are almost always "slip on".Im sure they are rusted on given your location.First soak the center with WD-40 then try tapping it from behind with a hammer or tapping the face of it to jar it loose (careful of the wheel studs)
Mar 11, 2007 at 12:10 AM
Suggested Repair
Rear rotors are typically slip-on and often stuck from rust. Soak the center with WD-40, then tap the rotor from behind or on the face with a hammer to jar it loose, taking care not to damage the wheel studs.
Conversation Summary
The owner of a 1993 Isuzu Rodeo was replacing rear brake pads and found the right rear rotor damaged after an inside pad slipped and the piston contacted the rotor. The rotor would not come off, and the owner asked where the axle nut was. The expert said rear discs are almost always slip-on and likely rusted, and advised soaking the center with WD-40 and carefully tapping the rotor loose.
