Blower motor not working
ISUZU
RDARCHE
I have a 1991 Isuzu pickup, 80,000 mi.
The blower motor does not work.
* I pulled the motor out, and connected it to a 12V source, and it works.
(it is a bit sluggish, so it may need to be replaced anyway)
* If I move the fan switch to one of the on positions, the AC will activate
(shows that the switch is good?)
* a voltmeter across the plug to the motor shows no voltage
* I also do not get a ground continuity at the plug to the motor
(assuming blue w/black stripe is ground, blue w/white stripe +12)
* bad wiring or relay?
Jan 20, 2006 at 12:02 PM
2CARPRO JACK
  • 11,533 POSTS
speed controller
Feb 2, 2006 at 7:36 AM
BASSERMAN
I think I have the same problem. I ran a few tests with the same results. By 'speed controler' do you mean the switch in the dash?
Thanks
Jan 30, 2007 at 3:51 AM
