1996 Isuzu Rodeo Wipers Kill Engine
1996 ISUZU
JEFF S
1996 Isuzu Rodeo,Girl friends SUV-V6 - 5 speed manual transmission 246K miles, but timing belt and water pump replaced last month. Overall decent mechanical conditon except for problem below.
Girl friends SUV, last week when windshield wipers were turned on it killed the engine and wouldn't run well after trying to restart. Mechanic fixed and said it was loose ground. Yesterday same thing happened, except engine runs fine when you restart. Kills engine though when wipers are turned on. Could it be a bad wiper relay or module or something?
Any insight will be appreciated.
Jun 4, 2007 at 9:50 AM
2CARPRO JACK
  • 11,533 POSTS
Hopefully we have a better season this year! Lonely being a Steelers fan in Socal! Is the wiper control on the steering column? Check the wiring to see if something is shorted out, that is what it sounds like, might be something obvious
Jun 5, 2007 at 1:06 AM
Suggested Repair
Inspect the steering-column wiper control and related wiring for an obvious short, and recheck the grounds previously found loose.
Conversation Summary
A 1996 Isuzu Rodeo stalls when the windshield wipers are turned on, then restarts and runs normally until the wipers are used again. A mechanic previously blamed a similar stall on a loose ground. The expert suggests checking the column-mounted wiper control and wiring for a short.
