1997 Isuzu Rodeo
1997 ISUZU
RUSS ENGLAR
I have a 1997 Isuzu Rodeo V6 w/100,000 miles on it and recently the2 dashboard light bulbs behind the right side of the dash - the side that shows the speedometer, oil pressure and gas guage - went out. the rest of the lights - dash, radio, heater, center console, etc. - are working fine. Do I have to remove the dash to replace them, or is it possible to access the bulbs by coming up from behind the dash?
Dec 27, 2006 at 1:19 PM
BASSERMAN
I also had the replace the dash lights. You cannot get to the lights from behind the dash. You must remove the front panels of the dash and then the instrument cluster. The bulbs go in the back of the cluster. Don't forget to disable the airbags first.
Jan 30, 2007 at 4:02 AM
