1996 Other Isuzu Models
1996 ISUZU
JORDANBLD
Engine Cooling problem
1996 Other Isuzu Models 6 cyl Four Wheel Drive Automatic
oil is getting into coolant but engine runs fine
Jun 17, 2008 at 3:52 PM
KHLOW2008
  • 41,814 POSTS
Hi jordanbld,
The engine might be running fine but there definitely is some leakage somewhere. It could be from the head, gaskets, oil cooler if it is water cooled.
Is there any signs of coolant in oil?
Is it trans fluid that is getting into cooling system? Check trans fluid for prsesnce of coolant. Would be milky in color. If that is the case, you need to replace the radiator if the cooling is through it.
Jun 21, 2008 at 9:54 PM
