2000 Isuzu Hombre 02sensor
89,000 MILES • 4 CYL • 2WD • MANUAL
JOE MCKNIGHT!
Check engine light came on scan codes came back 02 sensor replaced it light went out about 2 Hrs latter the light came back on.Is there some where you reset the codes.
Thanks
Apr 28, 2009 at 2:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You can delete the codes using the diagnostic scan tool or disconnecting battery cables for 10- 15 minutes. If light comes back with same codes then have cat. converter tested, a faulty converter will often throw a O2 code.
Thanks for using 2CarPros.com!
Apr 28, 2009 at 5:29 PM
