Is this a rod knock
180,000 MILES • 3.8L • V6 • RWD • MANUAL
THOMASGW
Hey guys,
About two weeks ago, my Genesis after getting revved to about 5000 higher than i normally do as i was accelerating off a merge, started making a light clicking sound , https://youtu.be/zophp-I-myw like a card between bike spokes. Kept driving it as i thought it was a bad gasket (no big deal was going to replace it ASAP) the sound got a lot louder until i thought it was a cracked manifold, or more likely a heat shield rattling as it sounded like metal on metal. Took it into the shop yesterday, was told the engine is toast because it has a thrown rod or cracked piston after about ten seconds of the mechanics listening to it :(. I am planning on replacing the engine, but I would like to confirm it is in fact a blown engine. If possible, could you guys take a quick look at the video? The sound is worst on start up after about seven seconds of the video I believe.
Thanks so much i really appreciate it.
Apr 14, 2017 at 9:20 AM
HMAC300
  • 48,601 POSTS
If you can disconnect spark plugs one at a time to see which cylinder it is and the sound goes away then it is that cylinder and probably a rod bearing. it may be a valve hitting piston too which you could tell by valve cover off like a broken valve spring etc. but it sounds like a rod.
Apr 14, 2017 at 11:55 PM
